Brainbuster-cutter comp in tight bores on Mazatrol
Here's a 300-level question I'd like some help with, guys....
If you take a 1.00 end mill cutter into a 1.750 bore to open it up using G-code from a Cam system, and using G41 cutter comp so you can control the bore to a fine tolerance, on a Mazatrol controller, I cannot make the approach long enough to satisfy the controller. But shouldn't the move from center to wall (which is .875) be enough to cover the 0.5 EM radius and amke the G41 happy?
Calling Cam-on-Mazatrol guru's out there......
