4 Attachment(s)
Error EX1098 M7598 X Y Axis Needs Zero Return - Mori Seiki NL2500 SY (Twin Spindle Y)
Hey Guys,
Just replaced my servo battery and I am now getting an error every time I turn on my Lathe
PLC Alarm
EX1080 (M7598) X, Y-AXIS NEED ZERO RETURN
Attachment 412787
I can go into the operation panel and set ZERO POINT ADJUSTMENT to "VALID"
I can move all the axis using the thumbwheel, but I cannot ZERO the axis via the front panel buttons
Whats the correct procedure?
The manual says to perform a zero return after an M70 error, but no mention of this above error.
I have tried to follow the procedure to zero the axis via the SYSTEM - NC SYSTEM - MENU - ABS SRV, but the ABS SRV options does not appear after I press MENU.
Attachment 412791
Attachment 412789
When I get into the settings, pressing the MENU button does nothing...
Attachment 412793
I have tried to set the NC WRITE PARAMETERS to "Valid" - no difference
Am i complicating this ?
Is there a zero return procedure via the front panel soft keys??
I have tried pressing the ZER soft key, then each axis, but no movement and no zero return.
Any help appreciated
