Re: CNC Router Build For A Friend
Hello there ! is there any finished pictures of this nice machine!,
Quote:
Originally Posted by
HuguesP
It went to the owner years ago as far as I know it is still doing fine work, I never completed the build on the Zone as I ran out of time, posting and running 2 businesses at the same time was hard to do, there was some information on the complete machine on another web site but that closed down and I was not able to retrieve anything from it, I did have the whole build on a computer which failed not long after that build was complete so don't have much to show but what is on this thread, I do have a new build that I may post about, now that I have a little more time, I'm keeping separate drives with any of this work I do now so if there is a problem I have a backup of the Backup, up until that computer loss I had had very good luck with computers, I even tried to go in the backdoor of the hard drive to retrieve files but it was too messed up to do anything with
Here is another build I did of a spindle at about the same time for a customer https://www.cnczone.com/forums/cnc-w...dle-build.html
Thanks ,
More interested in the machine, as I will never do my own spindle. My half 3d printed machine and hitachi router has is limitation, I need to upgrade if I wanna do bigger parts/ more complex.
HuguesP
Thanks ,
I may do another one a little bigger than that using a similar construction, say 25" x 25" so it can do a full 24" x24" sheet, it may have a steel main frame though
Waiting for this to copy the design, hopefully it won't have moving Z rails as i found them to create clerance issue of the gantry and cutting plane
HuguesP
I have a whole new Design for Z axes but still has moving rails that don't cause any clearance problems
