1 Attachment(s)
How to adjust the parameters of Steeltailor portable CNC cutting machine THC?
Hi all friends!Here is some informations about adjust the parameters of Steeltailor portable CNC cutting machine THC .Hope this is helpful for you!
There are eight parameters with SteelTailor portable CNC cutting machines THC, you don’t need to change most of them when you cut different thickness plate, maybe you need
to adjust A and b, A is the arc voltage, some user manual of plasma gives the arc voltage according
to the thickness of plate, see the chart below, it is from powermax45, it tell you the voltage, so you
can set, but some doesn’t give you the voltage, only give you the torch-to-work distance, this time you need to test the proper A value, different A value refers to different
distance, it changes with the plasma, you need to find out the proper value, it is not hard; b
value refers to the initial pierce height, but it is not initial pierce height, the default value
of b is 9, refers to about 4mm, if you want to increase the height, you increase b, test and find
the proper value. We suggest you don’t change other parameters.
Attachment 204640
Hope this will solve your problems.
SteelTailor is the world leader of Portable CNC cutting machines.
SteelTailor offers portable CNC cutting machines,portable table plasma cutting machine,CNC plasma and flame cutting machine,cnc plasma cutters
Home | SteelTailor portable cnc cutting machine gallery,product photo,cutting sample images
FAQ - Parts&Service - SteelTailor offers portable CNC cutting machines,portable table plasma cutting machine,CNC plasma and flame cutting machine,cnc plasma cutters
How to adjust the parameters of Steeltailor portable CNC cutting machine THC | SteelTailor' Blog
