Rotary error when rotating around z axis.
Hi guys,
I was ploting a program in wich my indexing head is rotating about the z axis. The program plotted alright. However the direction of the index was backwards. All my indexing heads are setup to rotate clockwise to the positive direction. I do know there is an option to reverse the direction. But it just get easy to forget specially when it rotates to the right direction when setup to rotate about the x axis. Can someone corroborate this ? As far as I understand I should not matter in wich axis the program is setup to rotate It should always rotate to the same direction. Am I right?
Thanks guys !
