VMC15 XT motor pulley and spindle pulley
Hello I am looking to see if any can tell me the depth of the pulley when mounting to the spindle motor and depth of pulley to the spindle? Have new motor, spindle and both new cog pulleys. This is for a VMC15 XT 7500rpm spindle.
Thanks for the help
2 Attachment(s)
Re: VMC15 XT motor pulley and spindle pulley
I appreciate you taking a look. I can't find anywhere in the manual that says the distances for the gates power cog pulleys. I think from the motor shaft end to the bottom of the pulley is .43". Would like to know for sure because you have to pull the motor back off to move the pulley. I think the spindle pulley is flush with the top of the inside of the pulley and the spindle shaft where the line markings are for the orientation.
Those were the only measurements I had but maybe someone else can help with the dimensions you need.
I snagged those a while back in case I ever needed them later. Hopefully not, famous last words.
if its a 7500 rpm pulley it should be the gates "poly chain" belt, and spacing. Unless you've got an odd belt setup, i've never seen a cogged belt on a fadal
..spacely sockets aka.. and a boy named elroy. in the passed
