4 Attachment(s)
NEW 4 Axis KL-6040T 1.5KW MACH3, Mach4 CNC ROUTER ENGRAVER 110VAC USB Connection
NEW 4 AXIS KL-6040T 1.5KW MACH3, MACH4 CNC ROUTER ENGRAVER/ENGRAVING 110VAC USB CONNECTION
Product link:
https://www.automationtechnologiesin...usb-connection
https://www.youtube.com/watch?v=zEB53rkT4TE
You can come to our show room in IL to check the machine
if you need 220VAC, let us know first
USA Tech Support (847-984-0882)
Package include:
1: 4 Axis 6040T 1.5KW Machine
2: USB Connection Cable
X Y Z Working Area: 600(Y) * 390?X?* 120(Z) mm
Outside dimension: 865*680*570mm?L*W*H)
Table size: 770?Y?*490?X?mm
Lathe structure: 6061/6063 Aluminum alloy
Stepping motor: NEMA23 two-phase 3A
Power: 1.5KW VFD
Spindle speed: 24000 rpm
Max working frequency: 400Hz
Principal axis collet: ER11collet
Nut Model: ER11-A
Cooling: Water-cooling
Repeat accuracy: 0.05mm
Computer connection: USB port
Maximum Idle speed: 0-1500mm/min
Working Speed: 50-1500mm / min
Re: NEW 4 Axis KL-6040T 1.5KW MACH3, Mach4 CNC ROUTER ENGRAVER 110VAC USB Connection
