Machine Parameter decoding !!!
Hi All
I am trying to get Numerical Control (NC)programs out from my CHMER 655C machine in my shopfloor.I got the below data from the machine , I am able to decode few parameters using information
from instrumentation panel in machine , can you help me to decode other parameters (Bold Below) if you could . Any help is really appreciated. I have attached the following codes below,
NC CODE FROM MACHINE
001 21 +0.000 +0.000 +0.005 +0.000 -12.393 000 000 215
13 17 3 10 10 3 6 8 1 1 0 0
30 3 0 16 4 0 6 8 100 60 0 895955
0 0 0 0 0 0 0 0
+0.000 +0.000 +0.000 +0.000 +0.000 +0.000 +0.000
Details from Control Panel for Respective program:
S-code:001
Ton: 50 Micrometer 13
Tof: 200 Micrometer 17
High voltage : 240V 2A
Low Voltage: 8A
GAP:10
SV0: 37.5% 3
Working Time : 0.6s 6
Jumping Time: 0.8mm 8
TW_UP: 0-900 Micrometer
Orbit Speed: 8
Jump Speed: 80%
Distance Setting: 30 Micrometer
ARC CT:30
APC CT:3
E-CODE:21
Set:0
Plane : XYZ
STP_JP:J4 +0x
Time_s: off
SV02: 100%
Finish : 100% +0c
TM SVO:Off
ARC :3 ON
Fire: ON
Fluid:Off
Back:Off
g-dry: off
g-step: off
TW_FWD:WOF JOF
D Gate: On
Light: On
End Up:20mm
BK_BLK:0
COOR:MACH
MOV_JP:0
Screen: off
Off PW: off
Spark: off
Beep: off
Oil AU: Off
Parameters I found Correlating above info
S-code: 001
E-Code: 21 – Plane Square-3D
W1. St. Angle: +0.000
W2. End. Angle: +0.000
Radius: +0.005. W3 Radius is 0.0002 Common factor multiply by 25
W4. DST: +0.000
W5 Deep: -12.393 Deep is -0.4879 Common Factor multiply by 25.4
13 – Ton (Pulse on Time) – Values can be between 1-24.
17 – Toff (Pulse Off) – Values can be between 1-24.
3 – High Voltage Steps
10 – Low Voltage steps Calculated based on High Voltage
10 – Gap Discharge Voltage
3 – SV0 37.5% Feed rate of an axis. Can take values from 1-16
6 - Working Time. 0.6s Can be from 0.1-10 second and denoted in 1- 40.
8- Jumping Time. 0.8mm can be from 0 micrometer to 33 micrometer and denoted in 1-120.
30 – ARC CT ARC Back step sensitivity. Default Value is 30.
3 – APC CT Prevent Massive current present in circuit. Default Value is 3. Range can be 0-15.
Regards
Santhosh
