High-speed Injection Molding Machine Selection Guide
What is a High-speed Injection Molding Machine
Generally speaking, the injection speed of an injection molding machine is above 300/s, so such an injection molding machine can be called a high-speed]injection molding machine. There are two types of high-speed injection molding machines, one is hydraulic and the other is all-electric. High-speed injection molding machine is a molding equipment specially used to produce thin-walled products. It makes many different kinds of thin wall plastic products, like food container, plastic cups...etc.
The Difference Between High Speed and Ordinary Injection Molding Machine
the difference between high speed and ordinary injection molding machine
The molding process of an ordinary injection molding machine is mold clamping-injection-cooling-material storage-mould opening-mould support-gap time.
The high-speed injection molding machine adopts three-axis linkage, which is generally called a three-circuit. The molding process is mold clamping-injection-cooling-mould opening (synchronous mold support, storage)-gap time. For example, the molding time of an ordinary injection molding machine for a product is 10 seconds, while the high-speed injection molding machine uses the principle of three-axis linkage to greatly shorten the molding time by about 6 seconds. Subtracting two small steps, the time is increased by about half.
The standard pumps used in ordinary injection molding machines have greater pollution in terms of electricity, hydraulic oil and noise. The high-speed injection molding machine adopts a hybrid type of oil pump and servo motor, which is very environmentally friendly.
What Are the Advantages of Choosing a High-speed Injection Molding Machine?
The shooting speed is fast, the ordinary injection molding machine is 100mm/s, and the high speed is generally above 300mm/s. increase work productivity.
Energy-saving, equipped with a high-response servo system, providing corresponding hydraulic oil output flow according to action needs, no overflow loss, saving energy by 30-70%. Reduce operating costs for customers.
Precise, equipped with high-end computer controller, precise position and temperature control setting, faster response.
High efficiency, the new optimized design of the clamping mechanism, the movement of the clamping mechanism is fast and stable, 10%-20% faster than the previous models. Optional servo motor feeding, shorten the molding time by 40% compared with the traditional machine (can realize feeding and opening The three axes of the mold and the supporting mold move simultaneously).
Safety, thickened structure, triple protection of machinery, hydraulic pressure and electrical appliances. The safety module independently controls mold closing, injection, feeding, and seating without any misoperation and human injury.
In summary, high-speed injection molding machines: implement soft-start molds, which will not affect the power network and avoid voltage and electrical radiation pollution. It can effectively prevent the oil temperature from being too high and cool down well. Greatly reduce the replacement rate of hydraulic oil. The servo hydraulic system has better click and power system gear pumps, which can greatly reduce machine operation and production noise and can better improve the working environment. Compared with ordinary injection molding machines, high-speed injection molding machines can save 60~70% of the total power, greatly reducing costs and saving resources for customers.
Which Brand of High-speed Injection Molding Machine is Better?
At present, there are many brands of injection molding machines in the market. We have listed some well-known and fast-growing brands.
Haitian International
ENGEL Holding GmbH
ARBURG GmbH
Sumitomo Heavy Industries
Milacron
Wittmann Battenfeld
Fanuc
Toshiba
Nissei Plastic
Husky
JSW Plastics Machinery
Toyo
Chenhsong
Yizumi
Sunbun
No one of these brands can tell which one is the best brand of injection molding machine. They each have their own advantages, and we should find suitable manufacturers according to our own conditions and needs.
How Much Does a High-speed Injection Molding Machine Cost?
What is the price of a high-speed injection molding machine? This is a question that many buyers will ask. Once you have the idea of buying an injection molding machine, you may want to know how to get the lowest price.
According to different specifications, clamping force, tonnage, system, motor, injection speed, and other configuration options. The price of high-speed injection molding machines will change accordingly. The price of a general high-speed injection molding machine is 50% more expensive than the ordinary injection molding machine. Usually, the price of a high-speed injection molding machine ranges from 10,000 to 100,000 US dollars. But from a long-term perspective, the profit return brought by high-speed injection molding machines is sufficient to make up for the cost gap.
do you need an injection molding machine?
Do You Need a High-speed Injection Molding Machine?
Sunbun is an high-speed]injection molding machine manufacturer from China. Mainly customize and produce injection molding machines for global customers. Our injection molding machine not only meets international quality standards in quality but also has a competitive advantage in price compared to peers. The cost of the same machine is reduced by about 10%. In addition, we also support, maintenance, professional technical guidance, machine solutions, parts supply, machine use training and other services. If you want to know about our high-speed machines, please click here. Please tell us if you have any needs and look forward to cooperating with you!
