Problem tension wire machine sodick AQ535L
Good day
The procedure was performed for calibration
without wire
VOUT and GND = 60mV
TENSENS and GND = 300mV
As indicated in the procedure
And turn on the machine. H00207 shows alarm. Tension abnormal press ENT to continue
And after a few seconds. E00180 shows alarm. Excess discharge time (SH) press ACK
Thanks for your time
Re: Problem tension wire machine sodick AQ535L
Quote:
Originally Posted by
mayelo82
Good day
without wire
VOUT and GND = 60mV
When I turn on the machine is servo drive MSDA013D1A. marks (ERROR 14 Overcurrent)
could this be the cause of the failure of the tension wire
Having problem with condition 777 showing short-circuit been told to change the fuse no clue where the fuse is any help will be greatly appreciated
