Re: Mach crashes my computer
Same problem here;
Motherboard: VIA Epia M with C3 at 800MHz
chipset: VIA Apollo CLE266 / VIA VT8235M
Tried to put LPT in EPP mode in both version 1.7 and 1.9 (in BIOS), but no luck..
[EDIT] Read somewhere that setting XP to "standard PC" instead of "ACPI PC" would fix this on the EPIA M 1000 Mhz motherboard, but it did not solve the problem om my 800 Mhz version.. [/EDIT]
running fresh XP SP3, Did not try windows 2000 yet..
Did you try the "Special Driver"?
It's been a long time, but some PC's just won't run Mach3.
Quote:
Originally Posted by
ger21
Did you try the "Special Driver"? It's been a long time, but some PC's just won't run Mach3.
Yes, it's an old thread, but still useful for us XP users :-)
And yes I've tried the special driver, but PC locks up as soon as test begins.
Guess PC's with this VIA chipset should be avoided for using with Mach3. (or perhaps use a separate LPT card, i've got one on the way from China now to test that)
Now that you mention it, i seem to recall the VIA chipsets were indeed the most problematic with Mach3.
