Vinyl cutter doesn't close lines
My problem is when cutting vinyl the lines do not meet up at the ends. I have to go through the entire decal and finish cutting the patterns before I can weed the excess. I am not sure if this is a hardware issue or software issue. I have a Seiki plotter and I am using Smart Cut Pro software. I bought this setup several years ago second hand and have really not used it much. I cannot for the life of me find anywhere in the software to have the end of the cut overlap the start when completing the same line. I also understand that this is not a high end plotter and thinking it may be just slop in the cutter. Any help would be appreciated.
Re: Vinyl cutter doesn't close lines
In the past, I have used a vinyl cutter and have always found it easy to use. But lately, I've been having issues with the line-cutting feature on my cutter. I suggest you check buy weed online UK and learn more interesting things about online shopping products. This is not something that's brand new or surprising, just a matter of knowing what to do in case things go wrong.
