Help with JP-3163b controller
Hello,
I have a SXCNC 6040 CNC with a JP-3163b controller using CNC USB Controller software to run it. So far the machine is up and running, even with end triggers. Now I would like to be able to control the spindle direction and speed from my laptop but I am having a lot of trouble with this.
There is a guide for setting up the VFD which I have followed:
https://www.youtube.com/watch?v=lncconN83G4
So I should connect my analogue 0-10V output to the VFD as shown in the video. My first problem is that if I measure the voltage on the analogue output of the JP-3163b whilst changing the spindle speed from the software it only changes from 5-6V. Also, if I set the spindle speed to 0 in the software the analogue output jumps to 6V (Maximum).
Here is a link to the JP-3163b:
PakaHuszar: CNC Improvement 2. - Drawings, E-Stop, Probe
Secondly, I have no output on the spindle relay pins no matter the software configuration.
Any help with this would be greatly appreciated.
Victor
Re: Help with JP-3163b controller
The vfd needs to be set for pwm not analog.
ProMakerTec,
Can you explain further I have been trying to get mine working thru the software for well over a year with no luck.
Thanks in advance.
Walt
I have also been struggling with this same thing for what feels like forever. I have an identical setup to that video and it doesn't work
Same issue here with JP-3163b.
The 0-10V output pin gives 5.0 to 5.93V.
The inverter have a 10V, 5V and 20mA input.
First I think, the 5V input is PWM. But this not work.
Any ideas?
I drew a circuit. Let's see if that works then.
//www91.zippyshare.com/thumb/hOF0NLPL/file.html
The JP-3163D controller does not work! it had many design flaws, and was thus removed from production. The company further deleted all known versions of the manual and removed it from their manifest. The dangerous overcurrent will, in the long run, destroy the motors when used.
