Re: ACRAMATIC 2100 problems
It sounds like you may have a bad hard drive that is not loading software files. The newest software is NT4.0 service pack 6. How old is your hard drive???
Mike http:// cncmachineservices.com
May be cmos battery is out. Try replace (cr2032), goto BIOS menu, set date-time AND set off any power management system. The same in realtime board, ONLY if battery is too dead. If you have RT board without PM system (recognize by chipset - if u see pins of any chip, this is propably w/o PM. If chips ic PGA ,propably have it - get attetions)
and the blinking vfs5 LED is totally separate issue: usually means you have lost the internal program inside the spindle drive. To repair that we need to replace the internal BRAM chip and reprogram the VFS5 - not something that can be done in the field.
Might this machine have been turned off for years and you are just now bringing it back to life?
my last reply ASSUMED you had no wires/connectors MISSING on the VFS5 drive; perhaps I should not have ASSumed?
Because the LED WILL blink showing drive is in autobaud state - IF connector C7 26 pin ribbon cable of the BDS5 located at top rear of drive has been removed.....
Did you get a new hard drive?? Did this fix your problem?? Let us know what is happening with this problem!!!
Mike CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
