Hi everyone,
I have a machine HEIAN 431p (Fanuc Oi-MC). I know M11 spindle #1 down, M21 spindle #2 down, M31 spindle #3 down, M41 spindle #4 down. M92 all spindle up. M95 all spindle off.
Who can help me how to do all spindle down?
Printable View
Hi everyone,
If there is no one mcode to do it all, simple write a 8000 macro with all the mcodes you need and assign it to an mcode.
Thank you under,
I think so., but what do i do now? Do you know parameter for this machine? I dont know unlock macro system program.
O8000;
M11;
M21;
M31;
M41;
M99;
What is the position in system parameter?
If you can find an unused M-code, i.e. M51, put that value (51) in one of the parameters 6071 to 6079. Some of these may already be used by the MTB, so find one that doesn't have a number in it.
Let's say 6077 is 0 or blank (I don't remember which it is). You set it to 51, and rename your O8000 to O9007.
Now, when you command M51, it will execute O9007 and bring all 4 spindles down, then return to the main program.
I am using AlphaCam mill program,
That is Fanuc 6MB
When i set T=1, machine works with spindle #1
When i set T=2, machine works with spindle #2
When i set T=3, machine works with spindle #3
When i set T=4, machine works with spindle #4
When i set T=5, machine works with spindle #1 & #2
When i set T=6, machine works with spindle #3 & #4
When i set T=7, machine works with spindle #1 & #3
When i set T=8, machine works with spindle #2 & #4
sorry, our company has 6 cnc machines. 1 fanuc 6MB, 1 fanuc 18M, 1 Xilog3, 1 Fanuc Oi-TC, 1 Fanuc Oi-MC, 1 Bacci 5 axis.
Do you know your CNC had PLC in side Fanuc controller or Heian use PLC out side of Fanuc controller. If Heian use PLC inside of controller you can find M-code by view ladder. If Heian use PLC out side of controller you must know which PLC was used by Heian and use special software of manufacture who made this PLC to load ladder and view it then you can find M-Code
I have a fanuc OM and M91 is all spindles down.
Hope it helps
