Best way to mount machine stand G0704
Hey Zoners! Been reading for a while, but just now getting around to really posting anything.
Sorry for the silly question, but I wanted to make sure I did this right so I didn't have to do this more than once. Seems like I've read about something like this before...but I couldn't find it when I searched.
I just got my G0704 and have the area scoped out where I am going to put it in my garage. The area is *MOSTLY* level. When I place the stand, I get a slight wobble. I have a .030" shim that takes out the wobble.
My question is - how do I get the most rigid setup? Should I try to anchor the stand down to the concrete without the shim? Or should I use the .030 shim and then anchor?
I assume using the shim is superior...but wanted to check with people with more experience to be sure.
Thanks for any feedback,
Doug
Re: Best way to mount machine stand G0704
You can use Anchor Bolts. They are the ones used to drill a hole and pound. You can check
http://www.raziqts.com/category/anchor-bolts/
You should Anchor it.
But if the vibrations are strong, it might affect the floor as well. I suggest you use Shock Absorber with Anchors for better results.
Here are the best anchors available:
https://www.albanycountyfasteners.co...chors/1440.htm
Tyche Gulf are the fasteners suppliers in UAE which provides all types of fasteners in UAE to build the mechanical connection or fixing more objects. Generally, fasteners are providing an extensive variety of latches that are utilized for secured and sheltered connection of any industrial structures. We are one of the top fasteners suppliers in UAE. We work for innovational concepts and have structured the light-weight latches that are the most useful for the hardware and electrical sector.
Fasteners suppliers in UAE
https://tychegulf.com/product-catego...ols/fastening/
