Probing for tool breakage
Hello everyone,
I'm in the process (for the first time) of setting up my tool probe to probe for tool breakages after each operation.
I have a 4th axis fitted. i have programmed to start my parts at A0 working around in 90 degree increments having 2 parts at each position.
So the last operation for T1 is A270, and I then want to check T1.
The problem I'm getting is the machine is alarming out as A is not at zero. Is it possible to edit the macro to disable this? As I don't want to have to send the rotary back to A home every time.
I hope this is understandable.
Any solutions would be much appreciated.
Many Thanks
Leighton
Re: Probing for tool breakage
Hi there
in process probing and tool checks are amazing i've been using it for about 2 years and have saved a whole lot of taps finishing tools
Just wanted to know if you are using the code generated by youre controller for the probe action or is it CAM generated .Ive had mixed results with the CAM ones .
And are you using renishaw probe system ?
If so i might be able to help
I just checked a tool at a odd A axis angle to be sure that i dont have the same issue and had none
1 Attachment(s)
Hi guys,
Thanks for the replies. I'm using the haas wips tool breakage template.
Attachment 490267
The image attached shows the 09025 program I opened it and deleted the part highlighted. This stopped the a axis zero position alarm and I'm now able to check tools during the program.
Leighton
I would put it between brakets, or jump it.
thus leave a trace, a reminder :)
2 Attachment(s)
Ive been using these two cycles that ive aliased to M303 (attended tool check O9003) and M304 (unattended tool check O9004) .It makes it easier to integrate as you dont have to re-post the code every time for each tool .The M301 stops the program if break is detected where as the M304 flags the tool then indexes a clean pocket (in my case always T2 ) then skips to a M30 to switch of the machine if setting 2 is .
I've made a copy of the original prg before editing so I will always have a copy. I went through the template for each tool and copied the code to a usb naming each one for said tool. I then copied the codes into the custom code within onecnc and just pulled each one in at the end of each cycle the tool has been used. I'm unable to set up sister tooling (clean pocket) as all my stations are full ( I've lost 3 stations due to large tooling)
