585,902 active members*
4,643 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Probelms with Huanyang Inverter VFD and Mk3 Board control
Results 1 to 12 of 12
    Oct 2022
    6
    Question Probelms with Huanyang Inverter VFD and Mk3 Board control
    My dad has built a CNC machine with a Mk3 board, he has a Spindle which he has wired to an output board following the instructions on the blog images of wiring at this link: https://imgur.com/a/4qpkEuH
    I have enable the 0-10v and control by terminals in the programs and setup the cnc as attached picture shows.
    The M3 command does nothing and the controls dont work either, what are we doing wrong?
    Jun 2005
    1730
    Re: Probelms with Huanyang Inverter VFD and Mk3 Board control
    Execute a couple gcode lines and measure voltage coming out of Mk3 board
    m3 S12000. Voltage should be about 5v do
    Then.
    M3 S24000 the voltage should be 10vdc
    Russ
    Oct 2022
    6
    Ok, no voltage output at all with those commands, I got some better pictures of the wiring if that helps
    https://imgur.com/a/iKVlZ74
    Oct 2022
    6
    Small Addendum, the output 1 puts out a max of 4.40V when at either 12000 or 24000, this is with a 12V power supply attached to the PlanetCNC Board
    Jan 2005
    15362
    Quote Originally Posted by Muldy29 View Post
    Next to the 0-10v output it has a Ground and 12v input this is most likely needed for the 0-10v to work, your wire being used is also incorrect you need Twisted Pair and Shielded is preferred you have to have the output from the Board working before you connect to the VFD Drive, you also need to remove the Reverse wiring as these Spindles are not to be used in Reverse
    Mactec54
    Oct 2022
    6
    Thanks, I will look into that, but now I have another problem, I have removed all wiring from the VFD and reset it to factory, but the VFD will not run the spindle using the touchpads on the front anymore, any Ideas, It was for a minute or two set to max frequency of 1600Hz in the Settings for PlanetCNC, could this have affected the VFD?
    Jan 2005
    15362
    You can't run the spindle with the Factory Reset Parameters you will damage the spindle, DO NOT RUN IT
    What is your spindle spec's
    Kw=
    Amps=
    Voltage=
    Hz=
    Mactec54
    Oct 2022
    6
    Apr 2013
    110
    A few years ago I also owned a Huanyang inverter (both the 1.5KW and the 2.2KW one). It's not hard to set it up...just read the manual (also found online). If it can be useful at the time I participated in a discussion on an Italian forum on this topic.
    everything is in Italian but with the Google translator there shouldn't be any problems.
    Jan 2005
    15362
    I will post the Parameters that need to be set
    Mactec54
    Jan 2005
    15362
    Here are the Parameters you need to set
    Huanyang Mactec54
    1.5Kw 400Hz 220v Water Cooled
    PD000=0 for Parameter unlock (1) for Parameter Lock
    PD001=0 (1 For Remote Control) (1 For 0-10v Terminal Control or Remote Trim Pot Control) (J1 Also Needs to be set for Terminal Control)
    PD002=0
    PD003=400
    PD004=400
    PD005=400
    PD006=260
    PD007=20
    PD008=220 (Motor Rated Voltage)
    PD009=143
    PD010=11
    PD011=120
    PD013= 08 (Is for Factory reset, only use this to set VFD to Factory Default Settings)
    PD014=8 (Acceleration Adjust to suit)
    PD015=8 (Deceleration Adjust to suit)
    PD120=120 (Stall Prevention)
    PD141=220 (Motor Rated Voltage)
    PD041=8 (Carrier Frequency max up to 10)
    PD142=6 (Motor Max Amps 7 for 1.5Kw Spindle)
    PD143=2 (Motor Number of Poles)
    PD144=3000 (Max Motor RPM) =3,000= (24,000)
    PD070=0 (This may need to be set to 1 if Control Voltage is 0-5v)
    PD072=400
    PD073=120
    PD174= (Set to Max VFD Drives Output Amp Rating)
    Mactec54
    Oct 2022
    6
    Thank you. It is working again
  1. Replies: 41
    Last Post: 03-15-2023, 01:14 AM
  2. Huangyang VFD YM-800A inverter - USB mach3 control board
    By Dhann73 in forum Machines running Mach Software
    Last Post: 07-29-2017, 06:51 PM
  3. Huanyang VFD Inverter all available Error Codes
    By Saintstone in forum Phase Converters
    Last Post: 07-08-2017, 11:26 AM
  4. Replies: 1
    Last Post: 11-20-2016, 04:58 PM
