585,763 active members*
4,069 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Problem with FANUC 15MEA-B-4 SYSTEM with DAHLIH hmc model MCH-800
Results 1 to 5 of 5
    Oct 2020
    4
    Post Problem with FANUC 15MEA-B-4 SYSTEM with DAHLIH hmc model MCH-800
    Dear Sir,
    We have one HMC machine from DAHLIH as above . Due to some reason machine parameters lost. Now we want to load all parameters to the system , we are following the process of loading as given below ,but system is not responding as needed. we are following process-
    NC on with 7 and 9 pressed simultaneously.
    IPL screen comes on as below
    IPL
    1- dump memory
    2- set file
    3- clear file
    4- file
    5- setting
    6- end IPL
    ? 99 (input)
    ? 23678625 (input)
    ? 37264699 (input)
    ? 19261161 (input)
    here our system comes back to IPL mode and not going to ask for AXIS ?
    and we are unable to proceed further for entering the option parameters 9000 series.
    we all ready have all the required parameters in soft as well as hard form.
    we feel pass word may be wrong ,but confirmed these are ok and getting typed from the MDI key pad perfectly.
    Memory card Base 0 card seems to be ok (A16B-2200-0520/11A) as the machine was working perfectly just before loosing the DATA.
    Data were lost due to human mistake.
    DAHLIH may change the standard pass word of fanuc ? or some other problem may be there.
    we are now looking for your help to go head.
    thanks and awaiting for your kind reply.
    S.K.gupta
    Apr 2009
    1379
    Re: Problem with FANUC 15MEA-B-4 SYSTEM with DAHLIH hmc model MCH-800
    The 15mea uses a different password. Send me a pm and I'll respond with the correct one.
    Change parameter 8000 & 8010 to all 1's then your option parameters will load with the CNC file.
    Oct 2020
    4
    I HAVE SEND PM SIR
    THANKS
    Oct 2020
    4
    We have one DAHLIH horizontal machining center Model DL-MCH 800 with Fanuc 15MEA-B-4 SYSTEM .
    Any one has PLC PC PARMETERS ?
    KINDLY REPLY
  1. Fanuc System P Model G
    By drgbt in forum Fanuc
    Last Post: 12-20-2019, 09:07 PM
  2. Fanuc system 6M model B
    By Olsson in forum Fanuc
    Last Post: 01-29-2016, 09:31 AM
  3. Fanuc 31i model b coordinate system
    By Bhard320 in forum Fanuc
    Last Post: 04-23-2015, 03:52 PM
  4. Replies: 14
    Last Post: 01-28-2014, 04:51 PM
  5. Fanuc System P model G
    By SGARCIAM in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-22-2009, 10:20 PM
