585,717 active members*
3,863 visitors online*
IndustryArena Forum > Other Machines > Other Machine Topics > Problem with ISEL. ISELDRV.EXE
Results 1 to 14 of 14
    Jan 2018
    7
    Good day to all.
    I have an old ISEL machine (PC running DOS with UPMV 4/12 card and I / O boards, drive control unit). I do not know its model. Recently, there was an error reading HDD and the machine stopped to be controlled. When you run the ISELDRV.EXE file, the "Program too large to fit in memory" error appears. It was not possible to restore the data completely. After analyzing the contents of the executable file, it appeared that ISELDRV.EXE was damaged. Does anyone have this file?
    I'm ready to install other software, but I'm not sure that it supports this hardware. Can someone had a similar and share experience? Or are there other ways to solve this problem?
    Thank you
    Attached Thumbnails Attached Thumbnails DSCN3409.jpg   DSCN3411.jpg   DSCN3050.jpg
    Jan 2018
    7
    Re: Problem with ISEL. ISELDRV.EXE
    ISEL controller is CV PV-3
    Dec 2016
    10
    I have a copy, I am just trying to install the USB drivers on the win98 machine so I can get a copy. I'll post it when i have it.
    Mar 2016
    323
    Did U try to use other software?
    Check galaad software (precisely Key programm). It should enable to connect any computer with Your machine. U can check demos.
    Jan 2018
    7
    Quote Originally Posted by steryd View Post
    I told with Galaad support and they said, that "Isel UPMV4/12 is a bit complicated since control is not direct from Galaad to the communication port. It requires the DLL and INI files that are provided with the machine." I have not these files for Windows and cannot find them for this time.
    What about Kay I didn't find my conroller CP PV-3 in demo-version. Did you find it?
    Dec 2016
    10
    I contacted Key for the same question - to update the machine, I would buy it tomorrow if it worked. They have tried to integrate the UPMV card in the past, but had some compatibility issues. They do not reccomend using it. If you could get it working, you still need to use the ini files etc
    ISEL RemoteWIN manual shows that it should be compatible with the UPMV card. I have asked for confirmation from our local dealer before I buy. I am waiting to hear back.
    RemoteWIN looks far better than RemoteDOS
    Mar 2016
    323
    I think i have remote WIN in my job. Not using it. U can try it if U want.
    Jan 2018
    7
    Thanks, of course I will try. Send it to me, please
    Jan 2018
    7
    Quote Originally Posted by rc-worcs View Post
    Today I take same answer from Kay.
    Isel have ProNC too, which should be compatible with the UPMV (before Win2000). Can this program control drivers?
    Dec 2016
    10
    that was painful!
    I have ISELDRV.EXE now. I cant seem to post it here. I shall try and message it .
    Dec 2016
    10
    Quote Originally Posted by habariniv View Post
    It should work, but I would need a copy of PRONC and the installation key to try it.
    Also I have RemoteWIN but no serial key. If you have a key I can try it for you.
    Jan 2018
    7
    Thank you, but I have not any keys. It is too expensive for me - to buy a key to try work))
    Do anybody have keys for ProNC or RemoteWIN for testing?
    Mar 2016
    323
    I can't find our copy. I remember we had all the box with manual etc., but can't localise it. Sorry.
    If i will get it soon i'll reply.
    Jan 2018
    7
    Thanks for all. Special thanks to rc-worcs. I copied good files and mashine back to life
  1. Wanted - manual for ISEL PC CV-3 servocontroller/ ISEL GFV flatbed
    By rc-worcs in forum Machinery Manuals / Brochures
    Last Post: 11-17-2017, 10:09 PM
  2. Techno / Isel / Tecno Isel confusion
    By H.I.P. in forum Techno CNC
    Last Post: 03-24-2014, 04:02 PM
  3. ISEL Re-ball
    By Georgie in forum Linear and Rotary Motion
    Last Post: 10-09-2009, 01:58 AM
  4. cnc router isel or lnv???
    By liakos in forum Engraving Machines
    Last Post: 10-02-2009, 03:29 PM
  5. cnc router isel or lnv???
    By liakos in forum MetalWork Discussion
    Last Post: 10-02-2009, 02:04 PM
