585,967 active members*
4,525 visitors online*
    Jun 2003
    242
    Problem with my old Fanuc 6T-b
    I'm running a program that I've run previously but with different results. I'm turning a sleeved adapter, boring the ID then turning the OD, the boring works as it's supposed to but the OD turning has odd and wrong results, it worked in setup and then got different results I turned the setup piece and then adjusted to OD by .0025 and things went wrong that I've not been able to correct.
    Part of the programming in question is below.
    O0200(SHAFT-ADAPTER)
    /G00 G20 G40 G97 G99
    /G00 G28 U0. W0.
    /G50 X0 Z0
    /G0 X-8. Z-5.(Z-8.)
    N100/G28 U0 W0
    /G50 X0 Z0
    /G0 X-8. Z-10.
    T0500 M8(3/4-TCMT331-BB)
    G50 X4.5000 Z3.6430 S1000
    G00 G96 X.875 Z.5 T0505 S500 M03
    G00 G41 Z.1
    G71 P1 Q2 U.02 W.01 D0500 F.015
    N1 G00 X1.075
    G01 Z0.002 F.008
    X1.014
    X.9843 Z-.015
    N2 Z-1.665
    G70 P1 Q2
    G00 G40 Z.5 M09
    G0 X4.5000 Z3.6430
    N200/G28 U0 W0
    /G50 X0 Z0
    /G0 X-8. Z-10.
    T0400 M08(CCMT332-OD-TURN)
    G50 X2.6500 Z6.0500 S1000
    G00 G96 X1.55 Z.5 T0404 S500 M03
    G00 G42 Z.1
    G71 P3 Q4 U.02 W.01 D0500 F.015
    N3 G00 X.90
    G01 Z0. F.008
    X1.22
    X1.25 Z-.015
    Z-1.175
    X1.4673
    N4 X1.54 Z-1.208
    G70 P3 Q4
    G0 G40 Z.5 M09
    G0 X2.6500 Z6.0500
    The ID turning works as expected but the OD tool takes passes at 1.4700, 1.3700, 1.2700, and semi finish pass at 1.2700, the g70 pass is at 1.2812 if i have radius comp at .0156 and 1.3124 if it's set at .0312. It seems to be reading the cutter comp in some odd way.
    I can't see what I'm doing wrong or is it a machine/control problem?
    Aug 2009
    1573
    Re: Problem with my old Fanuc 6T-b
    Quote Originally Posted by L98FIERO View Post
    G01 Z0. F.008
    X1.22
    X1.25 Z-.015
    Z-1.175
    ...some moves are to small maybe?
    Jun 2003
    242
    Quote Originally Posted by machinehop5 View Post
    Don't think so, those moves are a chamfer.
    The weird part is it worked in a previous run and during setup and then the problems. If I remember correctly the only thing I changed after the setup was the radius comp as my chamfer was too small.
  1. Problem Fanuc 18-T
    By Shukman in forum Fanuc
    Last Post: 08-12-2016, 03:32 PM
  2. Fanuc I/O Problem?
    By jorber in forum Fanuc
    Last Post: 10-17-2012, 01:24 PM
  3. Problem with fanuc 01
    By dopamine in forum Fanuc
    Last Post: 04-11-2010, 04:31 AM
  4. Fanuc new 0I problem
    By sylvain in forum European Club House
    Last Post: 12-30-2007, 06:17 PM
