I recently purchased a used CNC Precix router which is in great condition.
poppy playtime chapter 3
The problem I have is with the X axis. When I try to move the X axis, the X2 motor spins indefinitely, but the X1 motor does not turn at all.
I tested all the drivers and power to the motors, and everything seems to be working fine.
When I disconnect the X1 motor power cables on the back of the controller, the X2 motor doesn't turn. Any idea what may be the problem?
Also, do you think it is a good idea to retrofit with Mach4 (SMOOTHSTEPPER?) or LinuxCNC (MESA?)? Any suggestions?
Thank you!
