585,567 active members*
3,409 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC "do-it-yourself" > Profile-based 250x150x100 CNC - enclosed
Results 1 to 6 of 6
    Sep 2017
    15
    As a follow-up to my former post about CNC design:
    https://www.cnczone.com/forums/cnc-d...ml#post2470836
    I decided to make a smaller and chaper DIY machine. This time it went out from CAD :-)
    Initial goals were to have a small, desktop size, fully enclosed one, that can be also built nad used at home, powerful enough to cut alu. Structural frame and enclosuyre is based on alu profiles from ITEM. Working volume of 250x150x100 I managed to fit within the enclosure of 400x360x525, including all electronics. I used steppers integrated with trapezoidal screws (1,68A, Tr8x2). 10mm linear rails fully supported. SourceRabbit main board with USB. Daedalus spindle, 12kRPM, 0,5kW - one of a few cheap ones available that has a taper directly in motor shaft. Hall sensors on all axes in both directions. Electronics cabinet from alu sheets 1,5mm cut to size at local hardware supermarket, glued together. Milled parts ordered from Poland, some parts 3d-printed, e.g. backlash tuning, The machine runs 4,5m/min after calibration. I spent half a year of evenings to design and build it. It had cost about 3kEUR total. The biggest struggle was with 10mm linear rails supported. Most shops sell crap that cannot be even assembled and is out of spec. wrt. their own drawings.
    https://www.facebook.com/10000442884...55489725840242
    Sep 2017
    15
    Re: Profile-based 250x150x100 CNC - enclosed
    And this is how it performs. Video:
    https://www.facebook.com/10000442884...5697732547616/
    Sep 2017
    15
    In case anyone would like to have a look into the techncial details of this machine, I started wrapping-up the photos and footage of the build process into some simple YouTube videos. Part 1 of my video series is now live on YT! Enjoy and stay tuned for next episodes: assembly, tuning & upgrades and obviously - performance.
    https://youtu.be/EXMZiTE5eO4?si=RzBE43tro18eayt5
    Sep 2017
    15
    Second episode is live on YouTube, covering assembly process with lots of technical details:
    Sep 2017
    15
    Third episode is live, covering calibration/tuning and some minor upgrades:
    Sep 2017
    15
    Fourth episode is live, covering performance in variety of materials and quality of the parts. Enjoy:
  1. Replies: 35
    Last Post: 03-13-2018, 03:41 AM
  2. Paul's Semi Portable enclosed roll around CNC mill
    By Hezz in forum Vertical Mill, Lathe Project Log
    Last Post: 09-04-2016, 04:16 PM
  3. DIY Desktop Enclosed CNC Design & Build
    By yashodhanp in forum DIY CNC Router Table Machines
    Last Post: 07-09-2015, 01:44 AM
  4. Fully Enclosed, ready-to-run CNC Mill
    By sanche13 in forum News Announcements
    Last Post: 04-30-2014, 02:03 AM
  5. Will be grateful for your insight on the enclosed CNC router
    By Ariel6789 in forum Wood Lathes / Mills
    Last Post: 10-09-2009, 08:27 AM
