591,381 active members*
6,926 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Program transmission directly from the DNC to Okuma CNC with OSP5000M-G control
Results 1 to 4 of 4
    Feb 2021
    3
    I have an Okuma MC-4VB CNC with OSP5000M-G control, I have connected it to the DNC through the RS232 port, I can transmit (Pressing the virtual PID key, then READ CN0 and then the real WRITE key) the program to the machine's memory, but I can't get it to transmit directly (without being recorded in the machine's memory), can you help me by guiding me on how to do it? Since if the program has several lines it does not fit in the memory.
    I really appreciate your help
    Alfonso
    Aug 2011
    438
    Re: Program transmission directly from the DNC to Okuma CNC with OSP5000M-G control
    I can help you.
    Please enable private message
    "Imagination is more important than knowledge."
    Dec 2008
    3156
    Which method do you use... PIP or DNC ?
    PIP is the basic method, supplied with the machine. NOT capable with "drip feeding" a program.
    DNC is an add-on & CAN "drip feed" a program directly from a PC. Very big $$$ to fit the option on an older machine, parts may not be available.
    Others may chip in for alternatives
    Feb 2021
    3
    Quote Originally Posted by kurmay View Post
    I can help you.
    Hi Kurmay, can you help me?
  1. OSP5000M need run DNC
    By sun in forum Okuma
    Last Post: 09-09-2024, 03:45 AM
  2. DNC and CNC program revision control
    By NickGutt in forum DNC Problems and Solutions
    Last Post: 05-14-2024, 03:56 AM
  3. okuma osp5000m-g dnc problem
    By mangtonio89 in forum Okuma
    Last Post: 02-28-2018, 09:33 PM
  4. okuma osp5000m-g dnc problem
    By mangtonio89 in forum Controller & Computer Solutions
    Last Post: 05-20-2015, 12:06 PM
  5. Control paramater help. Okuma OSP5000m
    By Lafaso870 in forum Mastercam
    Last Post: 12-03-2010, 08:10 AM
