504,056 active members
4,346 visitors online
IndustryArena Forum > MetalWorking Machines > Okuma > Programming tailstock advance on program osp 5000
Results 1 to 10 of 10
    Benutzer
    Jan 2010
    101
    Hey
    I am making some parts that require tailstock so my program faces and centerdrill my part and I've manual reset and advanced the tailstock in MDI with M56 and restarted the program for now.
    I would like to advance the tailstock in the program but I had no luck.
    Tryed
    M05
    M157
    M56
    M03
    But the peogram stalls after the tailstock advance.
    Anyone can tell me how it's done ?
    Ps. My advance pedal dosent work aswell only the retract
    Sendt fra min EML-L29 med Tapatalk
    Apr 2009
    1121
    Re: Programming tailstock advance on program osp 5000
    Do you have tailstock advance confirmation?
    Normally foot pedal should work unless some interlock is preventing it Do you get any alarm? Does tailstock try to advance or doesn’t even try?
    If you check your I/O is the solenoid advance signal activating?
    Any other machine options that may be preventing it like part catcher or touch setter?
    Best regards,
    Experience is what you get just after you needed it.
    Benutzer
    Jan 2010
    101
    Quote Originally Posted by OkumaWiz View Post
    Best regards,
    I found out that the confirmation was not on so i adjusted it and not it works in auto and I can do it in the program. My advance pedal still dosent work it might be a lose connection. My retract works no problem
    I got have part catcher or tool setter on this lathe.
    Benutzer
    Jan 2010
    101
    I don't have tailstock and part catcher
    Apr 2009
    1121
    Go into check data and look for input from foot switch. Should be next to retract input.
    Benutzer
    Jan 2010
    101
    In the parameters ?
    Benutzer
    Jan 2010
    101
    I can't find where I can see it the foot switch is working
    Apr 2009
    1121
    It is not in the parameters but if you go to manual mode and extend a couple of times you should see a key that says check data. Push it and the page down until you see the EC Inputs. You will find it in there.
    Benutzer
    Jan 2010
    101
    Cheers mate. Will check it today when o get in the shop
    Benutzer
    Jan 2010
    101
    I can't seem to find anything under ec inputs.
  1. V25: Simple Part, advance programming
    By aldepoalo in forum BobCad-Cam
    Last Post: 04-08-2013, 11:15 PM
  2. Tailstock Advance on Hitachi Seiki Hi Tec-Turn 23SIII
    By Bob Dolan in forum Mori Seiki lathes
    Last Post: 05-10-2011, 04:51 PM
  3. Programming Tailstock
    By dcskid in forum Hardinge Lathes
    Last Post: 04-17-2009, 12:10 PM
  4. EA/ISO programming of tailstock
    By Alutrends in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-22-2008, 09:54 AM
  5. tailstock advance code
    By nitrosnfr in forum General Metalwork Discussion
    Last Post: 08-29-2007, 06:44 AM
