504,500 active members
3,533 visitors online
    May 2004
    68
    Proma THC SD hookup to Gecko G320
    I am trying to hook up a Proma THC SD to my Gecko G320 servo drive on a new Plasma build.
    The Proma wiring diagram attached looks simple enough but the G320 has a step, direction and common s/d +5v connection where the diagram shows a negative common.
    What would be the proper way to hook this up.
    May 2004
    68
    Re: Proma THC SD hookup to Gecko G320
    Solved.
    The older Gecko 320 only used a +5v common for step/dir. The newer G320X can have a common +5v or Negative.
  1. How do I connect Proma 150 THC to Gecko g540 and configure Mach3
    By jadog in forum General CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 06-05-2019, 08:34 PM
  2. gecko g540 proma thc
    By lexmotorsports in forum General CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 02-02-2018, 07:52 AM
  3. Replies: 2
    Last Post: 04-13-2016, 06:45 PM
  4. Replies: 0
    Last Post: 04-07-2007, 05:31 AM
  5. gecko 201 motor hookup
    By Don C in forum Gecko Drives
    Last Post: 03-29-2004, 03:46 AM
