529,766 active members*
2,833 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Protect rails and bearings from dust
    May 2020
    3
    Hi all,
    I'm looking at getting a kit from Avid CNC and planning to have it installed in the shed (on a farm), which gets very dusty. Does anyone know what sort of dust protector might fit a machine like that to protect the rails, bearings, etc. from dust in the environment? I've looked at accordion bellows, but the ends seem to be squared, but the carriers (e.g., those on the sides) on Avid CNC machines have awkward shapes.
    Any advice appreciated. Thanks.
    Jan 2008
    1115
    Re: Protect rails and bearings from dust
    Consider just covering the machine with big sheets when not in use. Old bed sheets are cheap
    Mar 2017
    207
    I've also looked into this a lot. There are some things that could be done. No matter what, you will have to custom make some things.
    I've been cutting aluminum more and it's hard to keep some of the chips off the rails. I saw one type that rolls into a cylinder like a roller shade mechanism. Different material of course. I then saw another person actually use a modified roller shade. They cut the mechanism section off and reattached the end. Put their own material on it. Something like an outdoor fabric.
    It is attached to the x sides and the z sides.
    I also saw some l shaped bellows that seem pretty easy to attach with a couple tapped holes or even using the ones on the z axis.
    I bought mine before they released the y covers. Mine are very similar to theirs. Printed some brackets and used outdoor fabric. Those work great. The x is more complicated though.
    Sent from my SM-N960U using Tapatalk
  1. Screw drives and linear rails and wood dust
    By Jandyman in forum DIY CNC Router Table Machines
    Last Post: 12-23-2019, 11:50 PM
  2. How to limit dust build-up on rails?
    By rlrhett in forum CNC Router Parts
    Last Post: 04-15-2014, 01:03 PM
  3. Need help on rails carraige dust issue
    By M.Abid in forum Techno CNC
    Last Post: 02-22-2014, 05:23 AM
  4. Dust on rails causing chatter?
    By Hyrum R in forum DIY CNC Router Table Machines
    Last Post: 05-17-2010, 12:42 AM
  5. Cheap dust cover for rails
    By DennisCNC in forum DIY CNC Router Table Machines
    Last Post: 11-13-2005, 02:18 PM
