547,444 active members*
1,556 visitors online*
Results 1 to 4 of 4
    PS191 alarm fanuc 6M
    so I have had this before in the past and never really been able to figure out the problem ,,, randomly when running a g03 it throws this PS191 alarm ,.,
    Accumax with 6M fanuc Attachment 468480Attachment 468482
    www.wildhorsemfg.com machinist / gunsmith
    accumax with Fanuc 11M , Hitachi seiki 3NE with 6T
    Re: PS191 alarm fanuc 6M
    not sure why I said 6M ,, its a 11M
    Apr 2011
    785
    An arc, where the difference of radius values at start point and end point is larger than the parameter set value, was specified. (parameter No. 2410) Fanuc book says modify the program.
    well yes , I did read what the code meant .. I just dont see how it could be causing a problem . The 11M manual shows that is a acceptable code
  1. Replies: 0
    Last Post: 08-12-2013, 09:12 AM
  2. Replies: 6
    Last Post: 03-13-2013, 03:32 PM
  3. PS191 Error????
    By Jokeapri in forum Fanuc
    Last Post: 02-09-2010, 01:39 AM
  4. PS191 error, need help FAST!!!
    By SpYnOnU in forum Fanuc
    Last Post: 11-20-2007, 09:51 AM
  5. Okamoto Grinder W/Fanuc 11M PS191 Error -- Help!
    By John Salisbury in forum Fanuc
    Last Post: 03-01-2007, 03:44 PM
