To whom it may concern,
We have the Miller Spectrum 625 X-TREME and XT40 torch which are operated by a Baileigh Plasma Table PT-22. We construct tool paths for the PT-22 using 'ucancam' software which has worked on other PT-22 plasma tables.
Our current problem however, is that the torch does not form an arc through certain areas, even though it should according to the programmed tool path, and tool path simulation.
In the link below, a program was previously run to cut the figure visible at the beginning. The same exact program was run again in the video, and the torch did not form an arc in the bottom right corner in the same exact location as the previous run. (However the tool path and tool path simulation were such that it should have cut).
https://drive.google.com/file/d/0B4x...JRSGNkTnM/view
Would anyone have any suggestions as to how we could resolve this issue? Please ask us if you require any more information to develop a solution. Thanks in advance for any support!
Regards,
Siddharth Shrivastava
Engineering Student
