544,019 active members*
2,443 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Puma 2600Y II Fanuc 0i-TF Pulse handle
    Sep 2006
    207
    Pulse wheel works ok to - direction, but when rotating to + direction movement is not smooth, machine stops suddenly and then starts to move again.
    Position is ok but movement is not smooth.
    There is 4 wire's coming back to pulse wheel, they seem to be ok when shaking.
    Wire's are marked A,B,0V, +V
    What could be reason....new pulse wheel or some card problem ?
    Thanks,
    GB
    Feb 2013
    757
    Re: Puma 2600Y II Fanuc 0i-TF Pulse handle
    Confirm pinout and voltages though the MPG by using the appropriate drawing for B31 or B32 setup
    If further assistance is needed, call my cell 973-803-9479
    Doosan Service Technician
    darryl.hardt@doosanmt.com O:973-618-2461 M:973-803-9479
    Sep 2006
    207
    MPG was faulty, new one was not expensive and machine rocks again.
    Thanks for help,
    GB
  1. Doosan 2600Y II
    By Green Button in forum Daewoo/Doosan
    Last Post: 12-09-2019, 06:33 PM
  2. MPG Handle problem - Fanuc Series Oi-MB
    By PlasmaManZA in forum Fanuc
    Last Post: 04-30-2018, 08:09 PM
  3. Combined straight handle and t-handle tap wrench!
    By northernmach in forum News Announcements
    Last Post: 08-20-2016, 02:32 AM
  4. Puma 2600y g17 milling
    By yellerrado in forum Daewoo/Doosan
    Last Post: 01-28-2013, 06:27 AM
