537,757 active members*
4,817 visitors online*
    Feb 2021
    Punch press problem
    Hello, I use an ermaksan punching machine. I have a problem with this machine, namely, it removes a very high degree on my sheets and treads my mold, breaking my punches after a number of sheets. I changed the tool holder, calibrated the machine, I called the maintenance but they did not discover the exact problem. Can you help me with some ideas? I have been struggling for 2 months to do it and he has the same problem. One more thing, all the stations with other tools are perfect, I don't have a degree, I cut well, so I don't have problems with them. Only with a certain station to fit my tool. Before I had no problems with it because I had cut seven thousand sheets without a degree without anything, recently it started to make me blunder.
    Aug 2008
    322
    Re: Punch press problem
    It sounds like something is wrong with that pocket . I would sharpen die and punch and move it to a different pocket .How thick is material ? What diameter punch are you using ?
    Feb 2021
    The metal sheet is 0.5 mm but i didnțt have problem with it before.
  1. Replies: 0
    Last Post: 09-22-2020, 02:14 PM
  2. Strippit LVD Turret Punch Press 1250 H20 - runs in dry mode, not with punch
    By Charlie-B in forum Uncategorised MetalWorking Machines
    Last Post: 09-22-2020, 01:31 PM
  3. centrum 2000 punch press problem
    By Timiza in forum Fanuc
    Last Post: 04-30-2018, 09:44 AM
