601,127 active members*
2,748 visitors online*
    Aug 2012
    QT-28N 128 Emergency Stop
    I'm powering up a '90 QT-28N and getting a few alarms.
    200 Thermal Trip (Emergency Stop)
    8 Battery Malfunction
    128 Emergency Stop
    The 200 Thermal Trip I can 'avoid' by powering up with E-Stop depressed. If not, I hear the contact breakers cycle a couple times and receive this alarm.
    8 Battery Malfunction is clearable
    I've been trying to trace the 128 Emergency Stop, looking through ladder and circuit diagrams. Nothing specific on 128 in the ladder.
    I found this diagram show the E-Stop circuits
    EMGB Relay is lit up. I think it's coming from NC, but not able to determine where/why.
    Servo Drives and Spindle Drive showing E7
    thanks
    Aug 2012
    Re: QT-28N 128 Emergency Stop
    Update: Found at broken wire at the thermal fuse on the transformer panel. Even though I tested continuity at the terminals days ago, failed to notice the broken wire.
    Everything is working except for Tail Body and Quill, and Tool-Eye retraction. Off to trace more wires.
  1. Problems with Emergency Stop/Stop function.
    By MrEmo in forum PlanetCNC
    Last Post: 10-19-2021, 10:47 AM
  2. emergency stop condition after E stop
    By Cosmin90 in forum Fadal
    Last Post: 01-14-2020, 01:30 AM
  3. With Mazatrol T32 Alarm 128 Emergency Stop
    By Bullet605 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-17-2012, 11:32 PM
  4. Generic Emergency Stop (E-Stop) Design Concepts?
    By zipzit in forum CNC Machine Related Electronics
    Last Post: 06-09-2011, 12:14 PM
  5. Alarm 128 QT-8 Emergency stop
    By grabolo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-22-2009, 07:24 PM
