586,024 active members*
4,064 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Question about checking shell mill length on the Auto Tool Setter
Results 1 to 4 of 4
    May 2013
    165
    I just purchased a second haas mill that will be coming in the next few weeks, and it has a wireless tool setter on it which I'm really excited about.
    In watching the videos on the tool setter when it's used with a shell mill I'm wondering how it works without either dulling the blades on shell mill, or how it doesn't create scratches grooves on the tool setter itself since the tool is spinning with it checks the height.
    I'm assuming the round disk on the tool setter is made of hardened steel.... but wouldn't this dull the blades on the shell mill?
    I know this is probably a dumb question.... but I'm just curious.
    Thanks,
    Kent
    Dec 2013
    5717
    Re: Question about checking shell mill length on the Auto Tool Setter
    The disk is carbide. The tool turns backwards when in the setting cycle. There is almost no pressure applied to the sensor because the spring is very weak. Overall it works very well and is very accurate.
    Jim Dawson
    Sandy, Oregon, USA
    May 2013
    165
    Thanks Jim...
    That explains things...... Thank You...
    a couple of follow up questions:
    do you have any issues with either coolant leaking into the tool setter, or the wireless probe?
    Any issues with chips catching and accumulating on the tool setter
    And lastly.... have you had any issues with the wireless probe loosing it's accuracy as a result of banging around from the tool changer?
    I probably sound like I'm trying to dream up potential problems on these tools... but I'm just curious if you have had any issues like this.
    Thanks again Jim....
    Kent
    Dec 2013
    5717
    Quote Originally Posted by kentdesautel13 View Post
    Thanks Jim...
    No. But our tool setter lives in a box, in the machine tool box. We have actually never used it. The receiver is constantly splashed with coolant and we have not noted any leakage.
    Since the tool setter normally is installed in a far corner of the table, there is little danger of chips catching it or doing any damage. When in use, any chips would be knocked off by the tool.
    We only install install the probe when using it, the rest of the time it lives in the tool rack.
    The one problem we did have was a low battery in the probe, it kind of went crazy and there was no indication of a low battery. Took us a bit to figure it out.
    Kent
    My Pleasure.
    Jim Dawson
    Sandy, Oregon, USA
  1. Another Aussie Auto Tool Zero Setter
    By Greolt in forum CNC Wood Router Project Log
    Last Post: 02-17-2019, 06:25 AM
  2. Syntec 21MA+ auto tool setter
    By Iglood in forum Chinese Machines
    Last Post: 04-13-2016, 05:51 AM
  3. Replies: 0
    Last Post: 09-01-2014, 06:20 AM
  4. Auto tool setter / touch plate ?
    By chrisnis in forum Machines running Mach Software
    Last Post: 04-06-2013, 12:24 AM
  5. Auto Tool Setter Button IH taylored !
    By Cruiser in forum Charter Oak Automation Support Forum
    Last Post: 08-06-2009, 03:25 PM
