544,152 active members*
1,600 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Vertical Mill, Lathe Project Log > Question on thickness of the sheet metal for milling machine chip tray
    Mar 2014
    999
    I'm going to make a chip tray for my Optimum BF20L build. I have a flux core welder so I might use steel sheet. How thick the sheet should be?
    I'll also welcome other suggestions other than steel.
    Best
    Jan 2009
    62
    Re: Question on thickness of the sheet metal for milling machine chip tray
    I will assume that the mill is on a workbench or stand.
    I would just fabricate a pan and sit the machine into it.
    Perhaps 48 inches wide, 30 inches front to back with a 3 inch lip in front and sides and 12 inches high in back to catch chips.
    Since it is made from folded metal, 24 gauge would be fine, 26 would also work.
    You will want galvanized metal if you are using cutting fluids. Many of them will eat away paint.
    I made mine out of stainless.
    You may want to take a sketch to a sheet metal shop.They can make the pan out of a single piece of metal and will braze or solder the corners.
    Light gauge or galvanized metal is not going to weld with flux core.
    They can also fold a 1/2 inch hem on all the raw edges to keep things straight and safe.
    If you do use fluids, think about soldering a drain.
  1. Replies: 0
    Last Post: 12-26-2020, 04:46 AM
  2. Sheet metal thickness measuring
    By bucknutz in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 01-15-2015, 10:44 PM
  3. Metal laser cutting machine is easier to achieve diversification sheet metal
    By mornlaser2014 in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 06-16-2014, 07:46 AM
  4. Chip Tray for 8x12?
    By flyman219 in forum Mini Lathe
    Last Post: 08-16-2007, 05:46 AM
  5. Steel thickness for slats and water tray walls
    By DeviousMW in forum General Waterjet
    Last Post: 03-15-2007, 09:26 PM
