585,954 active members*
3,974 visitors online*
IndustryArena Forum > Manufacturing Processes > Turning > quick change tool post for a grizzly g0602 machining.
Results 1 to 4 of 4
    Feb 2019
    i bought a shars quick change tool post and the thing comes with a block of metal that needs to be machined. I don't have a mill anyone know where I can just buy a premade base for the tool post?
    Feb 2019
    ok found one on ebay This is a pre made t-slot nut plate for Shars series 100 quick change tool post made of steel and has provided 1/4-20 set screws not shown. Fits grizzly lathe models G9972Z, G0602, G0602Z, G0752, G0752Z, and any other lathe with the same compound rest as many of the lathes are manufactured by the same companies in Taiwan, and china then painted to the manufacturers desired color. will also fit any other aftermarket tool post using a 14mm 1.5 pitch bolt. If you are looking to buy a quick change tool post and don't have a mill or the time to machine the block of steel provided to fit your lathe this is a convenient buy. This is a pre made t-slot nut plate for AXA series 100 quick change tool post made of steel and has provided 1/4-20 set screws not shown. Fits grizzly lathe models G9972Z, G0602, G0602Z, G0752, G0752Z, and any other lathe with the same compound rest as many of the lathes are manufactured by the same companies in Taiwan, and china then painted to the manufacturers desired color. will also fit any other aftermarket tool post using a 9/16 x 18 pitch bolt. If you are looking to buy a quick change tool post and don't have a mill or the time to machine the block of steel provided to fit your lathe this is a convenient buy. awesome these look great.
    Oct 2020
    12
    Re: quick change tool post for a grizzly g0602 machining.
    I think, yes, there is a lot of information here about your problem. Indeed, I saw several familiar to your question topics and specialists that are ready to do it for you. Maybe if you provide https://somamedicare.com/ a little more details here, I will have enough knowledge to do it for you. But what is about the experience?
    Oct 2020
    12
    I have set up and error questions, and I would bet will need parameters. https://calendardream.com/
