601,649 active members*
2,188 visitors online*
Results 1 to 4 of 4
    rack and pinion rough
    i have a second new k2 50 x50 machine and...
    this one has rack and pinion for the x and y axis'
    the machine works fine but the two axis' do not have a smooth movement,
    they seem a little rough !
    i am not sure if the adjustments on the gears are too tight or two loose ?
    any suggestions ?
    i have been cutting with it for almost a year but the roughness is driving me crazy !
    my first machine was all ball screws and is really smooth !
    should i expect the same performance from this one ?
    it seems every few inches it is repitetious up and down the table!
    help
    thanks
    bo
    Apr 2011
    did you ever figure this out?
    Dec 2007
    379
    I really cannot speak for the K2 machine but other machines using rack and pinion with atleast 3:1 gear reduction and steppers are getting very smooth cuts.
    Mar 2025
    Re: rack and pinion rough
    Did anyone ever figure this out? I have the same issue
  1. calculatiing pinion size for rack and pinion setup
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 08-06-2015, 11:18 AM
  2. dual pinion rack and pinion anti backlash
    By johngalt47 in forum DIY CNC Router Table Machines
    Last Post: 06-12-2011, 04:04 AM
  3. anti_backlash rack for rack and pinion
    Last Post: 05-25-2011, 08:25 PM
  4. Rack and Pinion- rack tensioned to pinion?
    By Rees Guitars in forum Linear and Rotary Motion
    Last Post: 05-09-2011, 06:05 PM
  5. rack and rack & pinion with off the self planetary gearbox
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 12-06-2009, 03:54 PM
