537,606 active members*
2,018 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Rack and Pinon Drive System for NEW BUILD
    Hey all,
    I'm new to the forum. I'm working on a design for a new CNC router build. I've been working on researching a rack and pinion drive system and hoping for some feedback. I'm building a 4' x 8' to 5' x 10' table. I like what I've seen the DamenCNC anti backlash rack and Pinion system. I worry about the issue of getting a product shipped overseas and the time and cost associated with that. I've also seen the system from Avid CNC, but I worry about the backlash with this type of system. Is there any other products that I can look to to get a preferably anti backlash or dual pinion system that works with Nema 34 stepper motors.
    I'm just worked on repairing a dinky 2' x 4' router table for my company. I'm looking to design and build a large table where we do design/build working with hardwoods. I've been an operator for large industrial machines and I'm looking to create a production level machine using mostly routing hardwoods, and maybe some aluminum.
    Thanks!
    Mar 2003
    35344
    Re: Rack and Pinon Drive System for NEW BUILD
    Anything low or anti backlash rack and pinion drive will likely be quite expensive.
    One option might be to use low or zero backlash gearboxes with helical rack and pinion. But zero backlash gearboxes might be hard to find, and very expensive.
    I'm using this on my new machine, but I haven't assembled it yet. I found some uses zero backlash gearboxes for AC servos for $250 each.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    May 2015
    566
    If you can build accurately, there is no need for the spring loaded pinions. If you need them, there is no point trying to use anti backlash components.
    Rod Webster
    www.vehiclemods.net.au
  1. Simi-Build: Microkinetics MN400 Controller Replacement Just Using The Drive Rack!
    By Contract_Pilot in forum Mach Software (ArtSoft software)
    Last Post: 10-18-2014, 10:16 AM
  2. Converting Standard N34 rack and pinon to pro
    By Dan911 in forum Avid CNC
    Last Post: 05-27-2014, 09:17 PM
  3. Stepper nema 42 rack and pinion drive system
    By EgyptianCNC in forum Linear and Rotary Motion
    Last Post: 03-14-2014, 11:13 PM
  4. Torchmate Rack and Pinon Gear Cleaning
    By PHSS in forum Torchmate
    Last Post: 04-26-2010, 04:38 PM
  5. Rack and Pinon Help Simple Question
    By Cartierusm in forum Linear and Rotary Motion
    Last Post: 10-05-2008, 11:54 PM
