585,987 active members*
4,654 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Rapid movement between boring commands
Results 1 to 4 of 4
    I'm using the circular boring with the use on simular or same size holes options. When moving from one the the next it uses the cutting speed which is very slow. How can I use a faster jog speed to move between holes?
    Mar 2016
    22
    Re: Rapid movement between boring commands
    Are you using personal version of Fusion? Then there are no rapid movement commands in the resultant gcode.
    Sent from my iPad using Tapatalk
    Quote Originally Posted by breezy1849 View Post
    It must be. It's the free version for hobbyist. Yet it will move fast to the first hole and between hole types.
    Mar 2016
    22
    The features being dropped from the free tier are:
    Probing, 3 + 2-axis milling (tool orientation), multi-axis milling, rapid moves, automatic tool changes
    Multi-sheets, smart templates, output options for drawings (print only).
    Download options from public share links
    Cloud rendering
    Export options including F3Z, DWG, DXF, IGES, SAT, and STEP
    Simulation and generative design
    Unlimited active and editable Fusion 360 documents (10 doc limit).
    Fusion 360 extensions
  1. Tormach Rapid Turn Y-axis movement
    By Coolant Slinger in forum Tormach Personal CNC Mill
    Last Post: 05-23-2017, 09:32 PM
  2. SL30 Tool overload in rapid movement
    By azrael4h in forum Haas Lathes
    Last Post: 11-18-2012, 02:22 PM
  3. Rapid movement and boards
    By traceflair in forum Fadal
    Last Post: 09-27-2010, 04:50 PM
  4. rapid c axis movement slow
    By chunkymonkey in forum CNC Swiss Screw Machines
    Last Post: 02-21-2009, 09:02 AM
  5. Rapid Movement after profile
    By shelburnebri in forum Uncategorised CAM Discussion
    Last Post: 10-02-2008, 05:43 AM
