I ordered this motor sec ago.
N5065 380KV 1665W High Efficiency Brushless Motor For Drones Multicopter Skate Scooter Skateboard Set DIY Electric Skate Board
it was a cheapest solution...
Specs are:
Model: 5065
Rotational Speed:380 (kv) RPM/V
Lithium polymer battery: 3S-8S
Nickel-cadmium / nickel-metal hydride batteries: 9S-24S
Propeller (inch): 16 * 10/18 * 10 / 18.5 * 12
Electricity adjustment (A): 80
The shaft length: 20mm
Shaft diameter: 8mm
Weight: 380g
Rally value: 3KG-5.5KG
Power: 1665W
Resistance: 20mΩ
Continuous current: 80A
Reactive current: 2A
Input voltage: 3-8Cells lipo
Effective utilization rate: 98%
Supporting oar size: 14x10 / 15x10 / 16x10
Motor length: 56MM
Motor diameter: 50MM
I want to build a spindle. I understood mechanical part, and i read a lot of old threads about electronics, but that is a very confusing matter for me.
I decided and ordered this motor to start with. Is it of any good?
So... mu primary question is :
What is the proper type of electronics (and cheapest solutions for ESC and/or other "elctro things" ) that i must buy to hook up this motor to arduino+cnc shield v3 setup that i already have?
Some explanations , schematic and links for parts would be most appreciated.
At the end, just to mention that, i do not expect much from this project. I just want to try.
Cheers.
