567,394 active members*
3,384 visitors online*
Results 1 to 7 of 7
    Oct 2003
    9
    Question Rebuild A Laser Printer?
    Does anyone know of any companys on the East Coast that will reburbish my HP5000 LaserJet (8.5 x 11-letter, 11 x 17-tabloid)? The print quality is fine, but the paper-pick up mechanics are worn out. The machine just keeps on jamming up. Would it be less expensive to purchase a re-mfg unit?
    Oct 2004
    727
    HP Authorized Repair Center Technician
    Where on the "East Coast" are you located? I'm an HP Authorized Repair Technician currently working for an Authorized HP Printer/Plotter repair company located in North Carolina (coincidence, or something else?). I'm authorized to repair almost everything HP allows us to repair from the original HP LaserJet to the expensive Color LaserJets along with most DeskJets and DesignJets. Parts for some of the machines have been discontinued and are getting scarce, though.
    I also have a basement full of HP LaserJet II, III, IID, IIID, IIISi & other miscellaneous printers (approx. 80 in all) that are in various states of repair/disrepair. My wife would love :argue: for me to get rid of some of them (hint, hint, nudge, nudge). Besides I need room to build and run my CNC router table (currently under construction).
    Gold Member
    Dec 2004
    524
    Quote Originally Posted by wocowski
    Did you try cleaning the rollers with some isopropyl alcohol? It did wonders for my LaserJet 4000N.
    Ken
    Kenneth Lerman
    55 Main Street
    Newtown, CT 06470
    Jan 2004
    111
    I used a product called rubber renue from MG chemicals, worked great, printer was working like it was new.
    Have a good one.
    Dave
    Oct 2003
    9
    Cleaning is not going to fix this one. This machine probably has more hours on it than all our CNC's put together!
    Feb 2005
    4
    Try to se if you can find the part here.
    http://h20141.www2.hp.com/hpparts/default.asp
    Feb 2023
    Re: Rebuild A Laser Printer?
    If you are interested to know how to rebuild a laser printer then I have written a guide on this topic. This is a guide to tell you how to rebuild a laser printer if your own machine fails or if the original cost of your machine is not affordable. I suggest you thermal printers to learn some new tips about printers. Rebuilding a laser printer is not something that you would do on a regular basis. It is more common to buy one, use it for a few years and then toss it when it gets too old to be useful.
  1. feedback isolator for laser
    By owhite in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 04-14-2007, 03:34 PM
  2. culprit: Printer Cable?
    By anthony in forum Mach Software (ArtSoft software)
    Last Post: 05-12-2005, 01:19 PM
  3. Laser Printer Servos
    By JavaDog in forum DIY CNC Router Table Machines
    Last Post: 10-17-2004, 12:37 PM
  4. drives and motors from laser printer
    By gv71 in forum General CNC Machine Related Electronics
    Last Post: 08-17-2004, 03:13 AM
  5. Rapid prototype CNC laser resin. (Stereolithography)
    By ynneb in forum Community Club House
    Last Post: 04-25-2004, 02:17 PM
