547,544 active members*
776 visitors online*
    Dec 2006
    125
    RECI laser tube unstable power output
    Just happen to have this problem yesterday.
    My 150w power RECI tube has very odd power output.
    We did test using paper; directly shooting out from the laser lens, and this is what we got:
    At low power 4ma the burn mark is a huge round circle about 1/2” diameter, without mark at the center.
    10-12ma is the best; small dot of 3mm diameter
    As it goes higher ma, the dot disappear; no lasted power output from the tube.
    Throughout the test, we could see the tube having its laser beam across the tube. But surprising at above 15ma there is laser beam across the tube, but no burn mark output at all.
    As I increases the power output I can see clearly the brightness of the laser beam across the tube increases, but yet above 15ma there seems to be almost nothing after the laser tube lens.
    Attached are the pictures of the burn mark.
    Sep 2015
    3
    Re: RECI laser tube unstable power output
    Did you ever find out what the issue was?
    I have a 150 w tube that does the same thing right now. Was working fine till i noticed a regression in output.
    Thank you.
    Quote Originally Posted by Syphonics View Post
  1. Measuring the power output of the laser tube
    By rjd1234 in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 08-04-2018, 12:08 AM
  2. RECI CO2 laser tube highest power
    By KKWinMyanmar in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 08-29-2016, 09:06 AM
  3. poor power on 100w reci tube. tube is new. 1290 laser.
    By nate in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 03-05-2015, 07:31 PM
  4. problem with PSU wiring for 80W Reci CO2 tube - only getting 4 mA output to tube
    By gbatten in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 01-06-2015, 12:53 AM
  5. Laser power output problem(unstable)!!!
    By khasabog in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 12-01-2006, 10:49 AM
