504,413 active members
5,080 visitors online
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Open Source CNC Machine Designs > Recommended DIY baseline design for two-spindle wood and plasma cutting CNC
Results 1 to 4 of 4
    Nov 2016
    9
    I'd like to build my first CNC with the following features/capabilities:
    * Able to cut a full sheet of 4x8' plywood
    * Two spindles, one for wood and one for plasma cutter
    * Removeable water tray similar to the CNC Router Parts design
    * Works well with Fusion360 CAM
    * Option to add a compartmentalized vacuum hold down table in the future
    Doesn't need to be particularly high speed.
    Any proven designs out there that could serve as a starting point for a system like this?
    Jun 2011
    677
    Re: Recommended DIY baseline design for two-spindle wood and plasma cutting CNC
    Have you thought about doing downdraft rather than water? Typically a bit bulkier, but I think it suits a hybrid system a bit better, not having water to deal with.
    Gold Member
    Apr 2004
    4816
    If space isn't a big issue, consider attaching an arm to the Z axis that reaches over horizontally to an adjacent plasma cutting table that can be fitted with a water tray. The plasma cutter doesn't have any resistance to deal with, so rigidity isn't as important as with routing. And you wouldn't have to dismount your vacuum table every time you wanted to cut metal.
    On the other hand, although some people don't seem to have a problem with it, I'd be disinclined to do woodworking in the same space as plasma cutting, which tends to spray bits of burned metal everywhere, contaminating the wood and possibly starting fires if they land in piles of wood dust. It seems like an operation best conducted in a separate shed of it's own.
    Andrew Werby
    Website
    Ryan,
    I use a large table with a 125A Hypotherm on a daily basis...
    So... I am very familiar with the mess that a reasonably powerful plasma can generate.
    As to it's comparability with a wood working table?.... how can I explain?..
    errrm.
    What do you get if you take the letter "F" out of the word; "Way" ?
  1. New Design Laser Wood Cutting Machine
    By stylecnc in forum News Announcements
    Last Post: 02-20-2017, 03:33 AM
  2. XY Plasma cutting table design plans?
    By Rich05 in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 04-06-2015, 10:54 AM
  3. Good gantry design for plasma cutting.
    By rbocaz in forum Mechanical Calculations/Engineering Design
    Last Post: 06-12-2013, 05:27 PM
  4. Replies: 1
    Last Post: 08-05-2011, 08:21 AM
  5. CNC setup to do wood and plasma cutting
    By videorov in forum Community Club House
    Last Post: 06-20-2009, 06:01 AM
