544,159 active members*
2,619 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Recommended Safety Switch for Mini Mill
Results 1 to 6 of 6
    Jan 2016
    386
    I am running single phase power to my Haas Mini Mill 2. Should I use a 2 pole or 3 pole switch? The mill is about 35 feet from the panel. Panel is in a different room.
    Jan 2005
    12411
    Re: Recommended Safety Switch for Mini Mill
    Quote Originally Posted by Steve303 View Post
    If you only have single phase then depending on what country you live in, NA 2 Pole and Ground 60A supply, is all that is needed, but it may be cheaper to buy the 3 pole but only use ( 2 ) of the switched Poles
    Mactec54
    Community Moderator Al_The_Man's Avatar
    Dec 2003
    23714
    For NEC/CEC A disconnect separate to the main enclosure is allowed for machines with motors totaling 2HP or less, as long as it is within 20ft of the operator and within sight.
    Albert E.
    Jan 2005
    12411
    Quote Originally Posted by Al_The_Man View Post
    He does not even need a disconnect, as it is already built into his machine, so he can run direct from the Breaker to his machine
    Mactec54
    Jan 2016
    386
    If that is the case it would simplify my install a little. I am in Ontario, btw.
    Jan 2005
    12411
    Yes that is all you need, 6-2 Plus Ground cable will do what you need this will help with Amperage drop over the 35 feet
    I have the same machines that run on single phase also
    Mactec54
  1. Replies: 10
    Last Post: 05-19-2021, 12:47 PM
  2. Haas Mini Mill Homing X Limit Switch Problem
    By esphobby in forum Haas Mills
    Last Post: 12-06-2017, 10:36 PM
  3. mini mill spindle switch between Mach & pot
    By mhackney in forum General CNC Machine Related Electronics
    Last Post: 07-10-2012, 09:45 PM
  4. Recommended tooling for X2 mini-mill
    By crazybrit in forum Benchtop Machines
    Last Post: 06-10-2011, 11:06 PM
  5. TM 2 safety switch
    By Bob Schneider in forum Haas Mills
    Last Post: 04-01-2011, 01:30 AM
