535,108 active members*
3,043 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > Red Light Flashing HBS86H
    Mar 2016
    6
    Hi All,
    I have a 6090 cnc Machine and Once I start my cnc the X-Axis & Z-Axis works fine but the Y-Axis after a small movement get stuck and Red Light Start Flashing on its HBS86HHybrid Stepper Servo Drive.
    Please check the below Video
    https://we.tl/t-pqJpZrxJyt
    My Motor is Easy Servo Motor 86HBM80-01-1000 leadshine.
    Please help. Thanks a lot in advance.
    May 2015
    38
    Re: Red Light Flashing HBS86H
    How many times the red flashes in each cycle? if it is 7 times, it means position following error, indicating that there is a problem with the encoder feedback signal.
    Potential reasons?
    1. The encoder is wire broken or bad connection.
    2. The motor acceleration is too large.
    3. The motor is overloaded during movement.
  1. Power Supply for HBS86H with Nema34
    By digdagdigedag in forum Leadshine
    Last Post: 04-15-2020, 05:01 AM
  2. VM-5020 Control board light flashing
    By marta621 in forum Milltronics
    Last Post: 03-05-2020, 07:42 PM
  3. Red and green light flashing
    By Bl@ckrat in forum Dmm Technology
    Last Post: 10-29-2014, 10:29 PM
  4. Light house flashing circuit
    By MrWild in forum General CNC Machine Related Electronics
    Last Post: 07-30-2010, 01:05 PM
  5. KURAKI KV-1000 FLASHING RED LIGHT
    By Scottjit in forum Fanuc
    Last Post: 11-19-2009, 07:05 PM
