547,522 active members*
1,392 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > reduce backlash = reduce noise/wear
Results 1 to 5 of 5
    Mar 2017
    48
    I have abit of dilemma;
    Purchased cheap C7 screw with SFE ball nut; (please kindly read on); after a run it sometimes makes a noise.
    Ball nut was making a like a crunchy type noise when table it was mounted on was viberating. Stopped table from viberting and the noise went. It is not practical for me. As if balls were juddering.
    I need better system. I cannot get double ball nut because of the pitchsize. They dont do a DFU in my size.
    What do you suggest is the best of the below actions please:
    1) get 2 single ball nuts and use a spacer in between
    2) I have been offered SFS ball nut but its the same length as mine. 47mm.They say its more precision but same number of balls cant see that working.
    3) get a C5 screw, dont mind because 3 times of $30 I can just about manage. Can ya trust sellers from ebay selling you a C5 that might be a C7; can you see a difference
    4) I don't even mind paying for a ground screw. In fact thats what I want from far east of course but I don't know where to look. Seems like rolled are more popular.
    Mar 2009
    1651
    Re: reduce backlash = reduce noise/wear
    1. a couple of ball nuts with reasonable pre-tension between them.
    2. check if the SFS ball nut you are offered has pre-tension capability.
    but first of all check your design against machne building rules. If your load on the ball nut is not too big.
    Mar 2017
    48
    Quote Originally Posted by Algirdas View Post
    50 kg vertical max load; screw diameter 20mm
    going back to ball nuts; so are we saying reduce backlash = reduced noise because we are ensuring the balls in there and not jiggling
    Mar 2009
    1651
    backlash should be eliminated at any case.
    Mar 2017
    48
    I see, so eliminate backflash first then , if noise or any other probs occur then deal with them at the time.
    i see the logic
  1. How to reduce noise in Control Electronics
    By M.RISHIKESH in forum General CNC Machine Related Electronics
    Last Post: 03-05-2015, 09:28 AM
  2. How to reduce CNC motor noise
    By Laurent_parti in forum Videos
    Last Post: 01-09-2015, 02:55 PM
  3. Oversize's BB's to reduce backlash
    By rs4race in forum Benchtop Machines
    Last Post: 03-30-2014, 07:30 AM
  4. 7 Ways to Reduce Tool Wear
    By CNCadmin in forum News Announcements
    Last Post: 10-10-2013, 03:25 AM
  5. Idea's to reduce backlash
    By truedblued in forum Mini Lathe
    Last Post: 01-19-2013, 07:28 PM
