585,880 active members*
6,090 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Reducing RF interference question
    Sep 2021
    5
    I have a question about reducing RF interference when wiring the Gecko 320X. Looking at the support documents for the 320X, I find it a little confusing. It sounds like that would be for a stepper motor. I am using a servo motor and that only has 2 wires. One positive and one negative. Should I use a shielded 5 conductor cable and use 2 wires connected to the positive and 2 wires connected to the negative and the 5th wire to the motor case. Or can I use a 3 wire shielded cable. 1 wire to positive, 1 wire to negative and the 3rd wire to the motor case.
    Below is the info from the Gecko 320X support documents.
    METHOD ONE:
    Use a shielded 5-conductor cable for your motor to drive connection; 4 of the wires go to the motor leads while the 5th goes to the motor case. Return the motor case wire to the drive’s power supply ground connection. Ground the shield to your electronics control box at the control box end only, leaving it disconnected at the drive end.
    Thanks for any replies!
    Aug 2005
    1091
    Re: Reducing RF interference question
    Yes you can use a 3 core shielded cable with a 2 wire dc servo motor .
    Cheers
    Peter
    Sent from my iPhone using Tapatalk Pro
    Homann Designs - http://www.homanndesigns.com/store
  1. Gecko G202 Reducing RF Interference
    By Biggermens in forum Gecko Drives
    Last Post: 02-21-2020, 03:33 PM
  2. Reducing RF Interference
    By redpeppery in forum Gecko Drives
    Last Post: 03-23-2017, 06:34 PM
  3. Reducing RF Interference
    By stirling in forum Gecko Drives
    Last Post: 04-09-2010, 04:40 PM
  4. New Application Note: Reducing RF Interference
    By CoAMarcus in forum Gecko Drives
    Last Post: 03-16-2009, 09:44 PM
  5. Reducing amperage?
    By stdly in forum CNC Machine Related Electronics
    Last Post: 02-23-2006, 04:23 AM
