584,833 active members*
5,612 visitors online*
Thread: Relay
Results 1 to 5 of 5
    Jul 2018
    11
    Relay
    Hi all, do I need a relay in the line from control board to spindel??
    Mike
    Dec 2003
    24216
    Re: Relay
    What board? what spindle?
    Here is a link for a G540 to VFD example, often it can be done this way, depending on the nature of the equipment I/O.
    https://www.cnczone.com/forums/spind...equipment.html
    Al.
    Albert E.
    Jan 2005
    15362
    Re: Relay
    Quote Originally Posted by 3dmike View Post
    Mike
    Would have to know what you have spindle Drive Spindle Control Etc. most likely not though, spindles don't normally run direct from a control board
    Mactec54
    Dec 2003
    24216
    Re: Relay
    I have edited and posted the correct link for direct interface shown in post #2.
    Al.
    Albert E.
    Dec 2003
    24216
    Re: Relay
    Also just in the process of checking BOB for using spare stepper outputs for VFD control, i.e. no relay.
    Al.
    Albert E.
