1. The area covered by planar re-machining changes depending on which direction is chosen. I don't understand why the region that is re-machined should depend on the cutter direction during the machining.
2. Planar re-machining misses areas. There are planar areas which are not cut by either the previous cutter or the re-machining cutter.
