535,108 active members*
2,750 visitors online*
Results 1 to 8 of 8
    Feb 2009
    12
    Renishaw RP3 probe disassembly (rant)
    So my RP3 failed after some use and curious about how it works, I decided to disassemble it. To my dismay the unit was made to prevent dismantling it, much less repair it.
    The kinematics are sealed in the stainless steel housing by means of a lip that is roll formed or pressed in at the bottom. I had to turn it down in order to remove it.
    Attachment 455286
    After turning down the lip I had to make a sleeve to knock the internal plastic out of the steel housing. If anyone is curious or wants to try it, here's the dimensions, which by the way I had to find by "turn" and error because it wasn't possible to measure it with a caliper. Renishaw really made it a point to make it a PITA to peak inside.
    Attachment 455288
    This is how it looks with the lip removed.
    Attachment 455290
    Also made a mini clamp out of aluminum to hold the housing down like so:
    Attachment 455292
    Inserting yet another special made sleeve with 3 slots cut out at 120° apart from the top and knocking that damn thing out.
    Attachment 455294
    Moment of truth... This is how it looks inside:
    Attachment 455296
    Attachment 455298
    Attachment 455300
    Re: Renishaw RP3 probe disassembly (rant)
    Wow!
    This is how a Renishaw probe is made?
    Thanks for sharing
    Feb 2009
    12
    Contnued...
    Attachment 455302
    Attachment 455304
    Attachment 455306
    Attachment 455308
    Attachment 455310
    Attachment 455312
    It appears the problem was many of the copper contact legs on the thin flexbile pcb were broken. Each leg measures about 0.5mm wide. The kinematics is designed in such a way that the balls form a divot on the flexible pcb, which in turn sit on the machined hole in the steel housing. With usage, the copper contacts eventually fracture at the divot edges. Poor design or wicked business tactic? How does Renishaw not foresee this as bad design? I think the latter is more likely, considering how much they charge for a replacement probe, and a refurbished one at that!
    For anyone who wants to know, a good probe should measure less than 100ohm resistance across the pins, mine was 200Kohm.
    Right now, I have to go draw up that flexible pcb and send it to some prototype printer shop and see if they can do it. I'll share the dimensions too in case anybody finds it useful in the future.
    Feb 2009
    12
    Attachment 455358
    Missed out an important detail... the plastic barrel that holds the spring has a pointy end solid rubber pad that, I assume, isolates vibration from the machine to the probe tip. The bottom of the probe tip actually pivots on a conical point above the spring.
    Spring wire diameter is 0.87mm, 4.625 total coils, 2.625 active coils single closed ends and ground, OD11mm & free length of 16mm. Appears to be of the music wire type. That would be 2.08N/mm. Preload is about half the free length, that should put it at minimum 16N of force on the probe bearings, not including the resultant force of the rubber pad that acts on the probe tip bottom surface.
    I hope this post is useful to the DIY probe builders here.
    It makes perfect sense that the tripod has a gimble between it and the spring, yet I had never considered that this is how they would be built. All of my probes have the spring acting directly on the tripod. Knowing that coil springs generally exert uneven force across their acting faces, it is obvious why this gimble is beneficial.
    Cool teardown!
    Feb 2009
    12
    Actually it acts more like a spherical joint than a gimbal mechanism, although you're right the idea is similar.
    I stupidly threw away the green goo in the housing before finding out it's actually dielectric fluid which quenches any sparks that may occur between the bearings and rods.
    Update : I mapped out the FPC and ordered 15pcs for $100. If anyone is interested in the DXF file shoot me a PM.
    Feb 2009
    12
    Updates on the PFC. Got some pics from the supplier. Can't wait to get it in the mail.
    Attachment 455912
    Attachment 455914
    Attachment 455916
    There are ball recesses on the new made parts? Not very clear in pictures...
    How's going the fixing process?
    BR
  1. Replies: 8
    Last Post: 01-11-2020, 11:39 PM
  2. G&L VTC1250 Siemens 840D - Probe error 21700 - Renishaw optical probe
    By 840DPROGRAMMER in forum Uncategorised MetalWorking Machines
    Last Post: 04-19-2018, 05:25 PM
  3. Replies: 2
    Last Post: 12-19-2017, 04:23 PM
