589,390 active members*
8,231 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Replace the encoder without reconfiguration
    Oct 2023
    11
    Hello everyone,
    I have a Fanuc 1-OSP/3000 motor. I would like to know if I need to reconfigure its position if I remove its encoder and replace it with another one.
    I would greatly appreciate any advice or opinions you could share. Thank you in advance for your help!
    Re: Replace the encoder without reconfiguration
    Quote Originally Posted by xryosmith View Post
    Hello everyone,
    Normally need to re-set the zero point of the encoder after replacement.
    Dec 2003
    24224
    You cannot change the position of the Fanuc red-cap internal encoder as it also has a 4-bit commutation tracks for the 3ph AC timing.
    It uses these 4 bits to create a pseudo sine wave for the commutation synchronization.
    The encoder is keyed.
    Albert E.
  1. Repair Panasonic Servomotor / Replace Encoder
    By ydemes in forum Servo Motors / Drives
    Last Post: 07-06-2023, 11:33 PM
  2. Emergency Mode/ReConfiguration Estop
    By sfco2000 in forum Mach Software (ArtSoft software)
    Last Post: 05-20-2022, 03:57 PM
  3. need to replace spindle encoder
    By samu in forum Fanuc
    Last Post: 02-28-2013, 06:16 PM
  4. Interact 720, Z axis encoder replace
    By Daninwyoming in forum Bridgeport / Hardinge Mills
    Last Post: 11-05-2009, 02:02 AM
  5. E32 encoder replace
    By tech5028 in forum CNC Swiss Screw Machines
    Last Post: 06-24-2008, 10:31 AM
